Centering the move/Scale/Rotate control
How to you adjust the Move scale rotate control to the center of a model ?
* You can also use the Pivot Mode to set the origin manually. Useful if you want it to be eccentric for whatever reason.
* It is in the default set for the tool bar unless you have customised it.
* PS: Most of us are bit eccentric for no reason :tongue:
