Cheetah3D 7.2 Beta 2
contrary to my original plans I've added quite some new stuff to v7.2 Beta 2. Please see the list below for all the new features.
Thank you very much the bug reports and the feedback. :smile:
New features in Cheetah3D 7.2:
New in v7.2 Beta 2
Attention:
Download link of Cheetah3D 7.2b2:
http://www.cheetah3d.com/download/Beta/Cheetah3D7.2b2.dmg
I hope you like the new features in Cheetah3D 7.2.:smile:
Kind regards
Code:
-upgraded form QTKit framework to AVFoundation framework
-supports modern video codecs
-JPEG
-H264
-HEVC (just on High Sierra)
-ProRes422
-ProRes4444
-better image quality
-multithreaded export
-much faster
-hardware accelaration if appropriate hardware is available
-added .gif exporter to Render Manager
-added support for the iMac Pro with up to 18 CPU cores (and 36 threads )
-added support for IES light profiles
-added support for filmic tone mapping to Falcon renderer
-added "Triangulate" property to Boolean creator object
-added "Triangulate" property to Boolean modifier object
-added support for SVG <circle> tag
-added bevel property to box object
-added bevel property to cylinder object
-added partial cylinder support to cylinder object
-added support for soft shadows to non-physical light sources in Falcon (doesn't use MIS yet)
-point light
-spot light
-distant light
-sky light sun
-added more steps to the quality slider in the JPEG export options
-JAS files are now exported with a proper UTI
-improved UI of external file link in properties editor
-removed old Cheetah3D 3.2 light sources (.jas loader converts them to Light objects)
-fixed bug in .obj loader
-fixed bug in .obj exporter (caused by objects with identical names)
-fixed bug in smart folder (could forget file path)
-fixed bug in torus object (could create zero area polygons when N1=0 or N2=0)
-fixed bug in movie save panel
-fixed bug with SVG <polygon> tags
-fixed undo bug when using steppers
-dropped support for Mac OS X 10.6 and 10.7
New in v7.2 Beta 2
Code:
-added quality property to JPEG movie exporter
-point light
-spot light
-distant light
-sky light sun
-fixed bug in GIF exporter
-fixed bug with SVG <polygon> tag import
-fixed bug in OpenEXR export (buggy alpha channel)
-fixed bug in light object (visible in editor didn't work properly)
-fixed bug in some retina icons
Attention:
Kind regards
