Which SVG editor you´re usually using?
The example SVG is quite experimental to my taste.
The tool script don´t seems to provide an UI element - is that correct?
Hi Oval,
that is a pretty impressive script. I'm always surprised what's possible with some Javascript magic. Getting the same functionality in ObjectiveC took me considerably more lines of code.:redface:
The attached SVG file is pretty evil. Where did you find it and do you know which application created it. It almost looks like a worst case formatting.
Especially the second path in the SVG file caused me quite some headaches. I didn't know that it's allowed to compress the path string that badly.:shock: :shock: But I will add support for that.
