Make sure you are in the correct 'mode' before using the select loop/ ring tools. If you want to select edges in a loop or ring go into 'Edge mode' etc the go to select loop/ ring. Use the transform function and select tweak mode to pick any polygon element.If you then click a highlighted edge it will select a polygon loop/ring both sides of the edge.
Thomas you should see something like this.
