Select an object and hide selection - not working?
hi folks,
I'm trying to select an object then click hide selection to hide it. Nothing is getting hidden - am I doing it wrong? Nothing is happening - bug?
Any ideas? All I want to do is hide a group/object so that I can work on the part behind it.
rgds/ RandyQ
What exactly are you doing?
Cheetah3d hides just polygons or whole objects or sets groups via Layers etc.
So usually you select polygons then go->Selection->Hide Selection.
Thats exactly what I'm doing. I simply select an object, then hide selection. But its not hiding.
Today I made an extrusion from spline - but this time no back/front faces. No idea why this is so because I have done this many times. I also opened a new file to make new spline & extrude, this time it is OK so my technique is correct.
I really am wondering if the installation is bad, because the behaviour is not consistent.
rgds RandyQ
I doubt that like I said in the other thread.
Splines have to be closed for front&back cover and for hiding polygon selections we need "real" polygons - make your parametric objects and extrude-creator objects "editable" first.
