OBJ + MTL export File
Who can help.
When i use OBJ + MTL export script i need a # before the last line in the mtl-file. Otherwise i can't import it to mObject.
So last line should look like this:
# WaveFront *.obj file (generated by Cheetah3D)
mtllib test.mtl
g Ebene
v -0.500000 0.480631 -0.137819
v -0.500000 -0.480631 0.137819
usemtl Material
f 2/4/1 4/3/1 3/2/1 1/1/1
#usemtl default
Can anyone post a modified Version of the script:
function main(doc){
var path=OS.runSavePanel("obj");
if(path==null){
return;
var file=new File(path);
var lastpathcomp=file.lastPathComponent();
var dir=file.directory();
var comps= lastpathcomp.split(/\./);
var objpath=dir+"/"+comps[0]+".obj";
var mtlpath=dir+"/"+comps[0]+".mtl";
doc.saveToFile(objpath,"obj");
doc.saveToFile(mtlpath,"mtl");
THX
tg_jp
#7
hi,
I think you want to change line 'usemtl default' to '#usemtl default' for .obj file that Cheetah3D exported.
if so, code will be ..
Code:
function main(doc){
    if(path==null){
    return;
    // comment out 'usemtl default'
    var objfile = new File(objpath);
    var objfile_mod = new File(objpath.replace(/\.obj$/, ".obj_bk"));
    objfile.open(READ_MODE);
    objfile_mod.open(WRITE_MODE);
    var line = objfile.readln();
    while( line != -1) {
        if (line.match("usemtl default")) {
            line = line.replace("usemtl default", "#usemtl default");
        objfile_mod.writeln(line);
    objfile.close();
    objfile_mod.close();
    OS.system("rm \""+objpath+"\"");
    OS.system("mv \""+objpath.replace(/\.obj$/, ".obj_bk")+"\" \""+objpath+"\"");
please replace OBJ+MTL export.js code to this, and test it.
Best
tg_jp, Hiroto
#8
:smile: :smile: :smile: :smile: :smile: :smile:
:icon_thumbup: :icon_thumbup: :icon_thumbup: :icon_thumbup: :icon_thumbup:
YOU ArE THE BEST
WORKS
GREAT AND MANY THANKS
