Polygon Paste.js
#41
I believe it isn´t working as your rotation value of the pasting object is reset and no longer corresponding to the choosing axis.
I made a similar object - put it in place - adjusted the rotation value- use the Y-axis and hit apply - bingo.
Thanks Frank.
I guess that is right - I called the 'coord system tool' and did some tweaking of the pivot point in such a way there is a rotation value, and that made it work.
I didn't realise that would be necessary, I was just thinking the direction the transform gadget pointed the axes would be the direction the mesh would be projected ...
I appreciate your help.
--shift studio.
frank beckmann
#44
If you reset the coords after adjusting the rotation values you can´t use the objects former direction as projection and just the 3 global axes will work (if the target is in the "line of fire"; see screenshot. Not sure if I can get it more clearly. ;)
Thanks Frank - yup, I'm getting how it works - just didn't get the verbiage.
One gotcha in this particular case, is that the mesh-to-be-pasted came from a mesh split from a more complex mesh that had no rotation. So, in other words, it didn't come from a parametric disc - object shown below - not that it matters now ;)
Anyways thanks for your help, and patience and great screen grabs or gifs to illustrate ideas.
--shift studio.
Polygon Paste is not working for me again. Before I go crazy, can someone confirm is still works in latest C3D (I'm using C3Dv7.3b4)
Thanks in advance!
--shift studio.
edit: I just tried the exact same sequence as Hiroto shows in his demo. It still works!
That means I'm doing something else wrong! I'm really unsure what though. :(
#49
I have the same problem with this one, one time I get it and the next I don't. :confused:
you get it to work and then next time with same procedure it fails? or you understand one time and then you forget?
Does it take a really long time sometimes? Maybe I need to wait longer?
Thanks, Shift Studio.
#52
I'm trying to follow Hiroto's video and I can't even get that to work.
I could use a step by step, I can't follow the sequence.
What is selected when the script is called?
Then I drag the target to the box and select
the polygon and change to "Y" and hit Apply?
#54
In the first part of the video it is set to object,
but yes I did, and I'm not having any luck.
I'm missing something, maybe some brain cells. :rolleyes:
#55
I got it working - I think it was because I was pasting a fairly dense mesh onto a very dense mesh.
I ended up with the spinning beachball.
I trimmed the very dense mesh down to just the parts I needed and then waited awhile - maybe 2 minutes.
@ ZooHead - in Hiroto's video, the mesh that is moving needs to be selected before hitting Apply. The mesh that will be pasted onto is dropped onto the 'Target Polygon' box.
--shift studio.
