Creators: Introduction
Helmut
Active member
2,484
Creators: Introduction 1
Creators: Introduction 2
Creators: Introduction 3
Creators: Introduction 4
Creators: Introduction 5
:D Thanks Helmut for zooming in on the properties menu in these examples. It really helps to understand better what is happening when one can see the various settings. Some of the properties menus in some of your compendiums are very little and it is hard to see them. If I try to blow up the images it only blurs and I still can’t read the settings and numbers.
I’m sure there are many Cheetah users that are greatly appreciative of your generous postings of compendiums.
My Best Regards
Jeanny
Hi Jeanny
Thank you for the comments. I would appreciate it, if you (and other viewers) make suggestions to improve the little introductory tutorials I create.
I wanted to include both some visual C3D samples and the relevant settings in the property panels in a reasonable compact way.
Grüße aus Vienna
Helmut
I like your use of a simple colored material to bring out key elements (I plan to imitate it ;-) ), but I think your examples suffer from being too busy and having too many unique and irrelevant details.
E.g. I'd suggest using the same (simple, preferably asymmetrical) spline in each example so the reader isn't trying to figure out what was done to what in each case. (Note that I need to follow this advice better in my own book. I only started being more consistent when I got to modifiers.)
