Make Circle.js
I need to get an english version of the demo any chance of this? I can't figure out how to use the tool.
Thanks this will be handy.:icon_thumbup:
Select at least 4 connected quads - call the script and hit "make" - or call Catmull Clark and then call the script and hit "make".
Really cool script. I get a different result with the top of a capsule--is this normal? Thanks.
hi, all
thank you for testing it. thank you. :smile:
I noticed several problems ( rotation gap with equal alignment ), I will update it for fixing these problems.
hi
I have updated this script. please check and replace it.
and I drew a chart for using this script. I hope it help to use.
In case that selected polygon curved ( a part of ball or capsel.. ), created circle is not fit to original shape. I will try to fix that problem. but for flat polygons has no problem.
Hi Hiroto,
wow, that's a really helpful script. I'm sure many will love it.:icon_thumbup:
Thank you very much.:smile: :smile:
I get this error message.
Javascript Error
line:137
error: 'undefined' is not a function (evaluating 'obj.recordGeometryForUndo0'}
What am I doing wrong?
which version of Cheetah3D do you use? Look's like the script called a new Javascript function which was introduced in Cheetah3D 6.0.
hi, thank you for testing.
I have just update it. please update it. for Cheetah3D 5.8, Undo/Redo functions are not available.
Hi tg_jp, I have tried to download this script three times and it does not download correctly.
I'm getting a generic document file that does not show up in the script/tool menu.
