Curls (splines)
Curls (splines)
Hi everybody,
I made an attempt to create a script which generates curly splines and more... (branches,...)
In my opinion, the script looks at its best, when used in combination with the sweep creator (scale set to zero). I hope you guys have fun with it and don't hesitate to make modifications/improvements to the script.
I still need to do some tweaking, be sure not to exaggerate, when setting parameters.
Since my programming knowledge is extremely poor, I had to rely a lot on Hirotos kindness, wherefore I would like to thank him!
I'll try to post some examples soon... (I would be nice if you share yours)
Place the script into:.../Library/Application Support/Cheetah 3D/Scripts/Splineobj
Have fun!
Filip
EDDIT: I added offset parameters...
  • Curls.js.zip
I noticed some strange behavior: when switching between Safari and Cheetah3d back+forth the output of the script alters slightly in 3d view without changing any values. Just by clicking the open Cheetah3d window to make it active. Anyone else?
Thanks Frank, I didn't notice that.
Programming is very new for me and I use a lot of trial and error, most of the time I don't even know what I'm doing, so I can't help you there... :redface:
What I'm planning to do is to make the randomizing parameters less sensitive, maybe that fixes some issues...
I will also try to include more horizontal bending options...
Kind regards,
Filip
Kind regards,
Filip
I´m not sure if it´s the script or a driver- or redraw-bug or what. Every time I return to the Cheetah3d screen with an open scene with your script the shape randomizes - but all values don´t. I´m just confused about that behavior not about your script. ;)
I have not seen the problem so far. Will keep trying a little more after lunch.
Oups : Just saw it too with several branches. Back to 1 branch and still have it. So, I guess it must be some other parameters.
I didn't manage to replicate the problem, but does it still occur when all random parameters (randomize length, randomize bend origin and randomize bend end) are set to 0?
