Particle Connector.js
Hello
It's a spline script to create spline as connect all target particles.
Place it into ~/Library/Application Support/Cheetah3D/scripts/Splineobj folder to use.
[download] http://www.tres-graficos.jp/blog/files/article.php?id=81
[update] 20120119: fixed curve bug, improved distance calculation.
[update] 20120121: improved distance calculation.
[update] 20120125: change angle setting code, curve center parameter added.
Pointers, Instructions or Tutorial
Good Morning Dear Forum
I've downloaded the script, put it in splineObj and dragged a Particle Array into the 'target particle' drop box.
For the 'curve center' I've dropped a sphere which was the child particle of the Particle Array.
Nothing has happened, so I'm not so sure about what to next.
Could someone give me a nudge in the right direction please?
Regards
Andy
  • NetworkBalls.zip
* input higher value for 'distance threshold'.
* set another object for 'curve center'.
script makes spline as lines to each particles.
if you move object set to 'curve center', curve direction of lines changes.
Best
Got It! Now for making the splines into tubes!
Hiroto
Extra Double thanks .. Here's where I got to:
I've been having play at trying to get the splines to be paths for tubes, but without success. I guess that these need to be children of the 'Particle Connector' ?
Thanks Andy
  • NetworkBalls.zip
hi,
no, Sweep creator object requires 2 children, profile and path.
please check attached image.
Best
I´m not sure I understand. Do you want the particles A) kind oF slide along the splines or just B)splines be generated between new particles?
A) Not possible afaik
B) will work with higher value at the "distance threshold" property
