Spline Wrap.js
Spline Wrap.js
Hello.
It's a polygon script to transform polygon object along spline path.
place it into ~/Library/Application Support/Cheetah3D/scripts/Polygonobj folder.
http://www.tres-graficos.jp/blog/files/article.php?id=69
[update:20110513b] adding new paramters.
how to fix twist problem.
and, this script have a known problem.
A circle spline causes twist transform problem. To fix it, rotate circle spline object, and rotate back wrap object.
[updated] if you have this problem, change 'spline rot' parameter.
wow, thank you for comment and nice movie.
actually, this can make very interesting effect. :cool:
Is there a way to have materials within in the script hierarchy?
I expect that, too. ( did I get what you meant exactly? )
btw, please update it if you have first version.
p.s. could you test my another project in your spare time?
It´s really amazing :icon_thumbup:
The materials on the mesh inside the "Spline Wrap" script won´t show up in render - did I miss a step? I think I used the latest version.
I didn´t recognized there´s any public version yet? I´d like to try for sure.
nice material.
about material thing, all info ( UV and polygon selection ) are copied to Sline Wrap object from polygon object.
