Cheetah3D 5.7 Beta 2
Moderator
9,479
here is the first beta version of Cheetah3D 5.7. The biggest change in this new version is probably the new preferences window and the support for exporting animation data to Collada files. But also the possibility to load camera animations from PFHoe Pro (via FBX) should be a great addition to Cheetah3D.
http://cheetah3d.com/download/Cheetah3D5.7b2.zip
Since this is beta software please don't use it for important work or data.
Please post bugs or problems you encounter with this beta version in this thread.
Attention: Cheetah3D 5.7 copies the render history to
"~/Library/Application Support/Cheetah3D/Render History"​
So older version won't find the render history anymore. I decided to do that since some clean up tools tend to delete the render history in its original folder "~/Library/Caches/Cheetah3D/temp" were is was before.
Here is a list of the new features and the bug fixes:
-completely new Preferences window
  -preferences window has toolbar
  -all menu commands can now be bound to hotkeys
  -scripts can be bound to hotkeys
  -many colors are customizable
  -preferences window is now also accessible when no document is open
  -many new preferences
-extended Collada exporter
  -added animation export
  -added skinning export
  -added second UV set export
-added support for PFhoe Pro via. FBX files
-extended Target tag
  -added offset parameter
  -added Up-Vector parameter
  -target tag now aims on pivot point
-SSE optimized subdivision surface algorithms
-scripts can now only be installed in the "~/Library/Application Support/Cheetah3D/scripts" folder
-moved render cache to "~/Library/Application Support/Cheetah3D/Render History"
-camera guidelines are now always visible
-rotation angle is displayed in status bar
-added "Rotation step size" property to transform tool
-line antialiasing is now a global preferences
-increased UV transform gadget selection sensitivity
-improved drag&drop in object browser
-ruler tool also support parametric objects now
-changed default near clipping plane to 0.01
-added work around for Bamboo problems
-unified Play and Stop menu commands
-fixed bug in obj loader (negative indices)
-fixed numerical problem with euler rotations
-fixed disappearing particles bug in renderer
-fixed background gradient drawing bug
-fixed non-stoppable animation bug
-fixed bug in transform tool (free rotate failed)
-fixed normal export bug in .obj exporter
-fixed .hdr loader bug for big textures
-fixed bump mapping bug
-fixed texture painting bug
-fixed bug in HSV2RGB node
-fixed polygon selection bug
-fixed bug in .obj exporter
-fixed IK bug which caused scaling of joints
-fixed bug in extrude tool
-fixed snapping bug to hidden polygons
-fixed snapping bug to invisible objects
-fixed normal breaks crashing bug
-fixed bug in shell tool
-fixed bug in pose tag (table view)
-fixed bug in morph tag
-fixed bug in skeleton tag
-fixed bug in take manager
I hope you like these new features.:smile:
Kind regards
just tested (not that I don't trust you...): the "big-hdri-loading-bug" is now gone and loading time seems quite reduced to me... that's a huge improvement for me, thanks!
Hi Alessandro,
thanks for the confirmation that it is working properly now.:smile:
Hi Alessandro,
here's a test with a 10000x4000 158Mb HDRI used as true IBL: :icon_thumbup:
I've updated the original posting to Cheetah3D 5.7 Beta 2. Beta 2 fixes the following problems.
    -fixed subdivision bug
    -fixed camera guideline color bug
    -fixed crashing bug when changing file loader preferences
    -some more optimizations
Kind regards
Kind regards
Hi Martin,
Awesome! I see a list of many improvements of features I often use the most and did notice, some more than others.
The scaling of joints was of concern with the IK handles, so I'll take a look when I have 5.7 downloaded.
I'm interested in seeing the new Target Tag features, as my animations value the target tags in almost every scene. Thanks!
Non stoppable animation was another question I was going to mention, but you already addressed it.
The new preferences should be great. Thanks for all you do to improve Cheetah 3D Martin! :cool::icon_thumbup:
real fast beta update martin!!
this might sound silly to others, but i'm glad to have bottom & top color in the view. makes it easier to distinguish and get to back to proper orientation if i rotate the cam too wildly. :D
any idea/peeks whether we are going with 5.8 or directly to 6 after this? ;)
5.7 Beta Feedback
Hi Martin,
I don't know if you want beta feedback in this thread, but here you go.
Key command for Render no longer works. Previously it was "Command R" on my keyboard (aka "Apple R").
Thanks for the beta.
Mark Edwards
Hi Mark.
Cmd+R still starts the render engine - do you have another function mapped to that key combo? Check your preferences.
<do you have another function mapped to that key combo?>
Nope. I can assign it, but it's not assigned by default (maybe I assigned it myself in 5.6?).
--Mark
--Mark
I think Martin should take the hotkey from the main "Render" menu as it is now configurable by user.
