mars0001 (Offline)
Default Help needed on Create a Giftpack from cutterguides - 23.02.2011, 11:15
Hi guys,
Can someone help me please to get started on my new project?
What I want to do is to create a gift box from the cutterguide (attached), finally I want to map the artwork so I get a realistic 3D model! Were I get stuck now is "folding" the line to get it in the right shape (it's all 90˚, but somehow I'm missing something!?)
thanks in advance!
fused (Offline)
Default 23.02.2011, 12:21
Originally Posted by mars0001 View Post
Hi guys,
thanks in advance!
You could make each panel a polyplane object. The new transform tool should work great with snaping to component. I'd made each panel a compound path in Illustrator, save as a svg or pdf and import. Then add each panel to a polyplane creator.
Or make the profile a coumpound and import, add to a polyplane and make editable then use the scalpel tool to cut the creases.
Having said all that, I'm sure this has been covered somewhere else. There's a bunch of different ways to do it. Depends what you want really.
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
