Simple Die Tutorial
Andreu
820
Simple Die Tutorial
Hi all, I just created a simple introductory tutorial with the compulsory die in it :) I hope it's useful. You can view a better quality image on my blog.
Enjoy!
Lowbandwith
Thanks !
I do have a very low bandwith > video tutorial are a pain for me :frown:
I did the tutorial also. I enjoyed it as it had clear concise steps, and pictures...
I did however have an issue with the extrude after the inner extrude.. I set the setting like you showed and the extrude made the circles go outward.. A simple normal move after that and they then moved as the steps showed.....
John, thanks for pointing that out, I may have to re-write that part. When you first click to extrude, it's true the extrusion tool moves the polygons outward. You need to keep holding the mouse button down and drag a bit (I can't remember in which direction now) until you get that result. It's not too hard, but it's not obvious either.
