Importing SVG and converting points/lines to 3d objects
ibzero
4
I'm new to cheetah but so far i'm impressed with the ease of use. I'm having a little trouble understanding how best to accomplish the following.
I have SVG file of a graph (sample attached) and I want to import it and then have the lines converted to tubes/cylinders and the nodes converted to disks.
Since the lines are imported as bezier splines, is there a way to take an instance of an object and then do a copy parameterized instance to splines? If so any pointers would be appreciated. (Basically hoping I don't have to manually extrude each spline/line and add the points.
IB
  • smallworld_100.svg.zip
Hi and welcome.
Are you expecting a scriptable solution as we are in the scripting area of the forum? If not - have a closer look into the attached file and let´s hope it might help you start with your project.
Your SVG is quite scary and I don´t know what you´re after right now.
I made a simple file from 2 splines and Cheetah3d´s instancing system. That means I have a ball per control point and a sweep object from the same spline plus a six-sided edge spline as a diameter.
Have fun.
  • InstancingPerSpline.jas.zip
Frank,
Thanks for the quick turn around. Your example helps, but I was hoping for a scriptable solution (programmer/designer by trade). The SVG is a social network graph and I need to be able to import several of these and turn them into 3D objects (although really they'll be 2d planes extruded and overlaid onto of some 3D environment scenery.
I would like the lines to act as springs for animation purposes (e.g. one of the visualizations involves introducing an impulse on a node and watching the waveform propagate through the network. I did find another post where you mention importing as pdf (this worked better for me and I was able to extrude) but when importing as a pdf it treats the entire network as one object which is problematic as i need to be able to color nodes and edges as part of the animation.
I'll take a deeper look at the example you sent and see if I can get where i need to go. If I haven't made things clearer in the above, please disregard and i'll wait till i can ask a better question.
IB
Hello
here is script's approach. please check it.
it's a Tool script, so place it into ~/Library/Application Support/Cheetah3D/scripts/Tool folder.
I tested with your file, and some my svg file.
  • SVG Graph Loader.js.zip
This is awesome, I had to resort to manually doing this for a short term deadline, but this is exactly what I was looking for to start diving into the scripting capabilities of C3D.
Thanks again, its refreshing to find a true community around a tool and with such helpful guru's.
IB
Oh and for the search engines: This is a possible solution/pipeline for visualizing network graphs in 3D with gephi and cheetah3d
Hello
Great script, thank you!
I'll take it for my own future script.
But it has some minor bug in S(s) svg tag handling.
here is mine:
[B]var cpx_last,cpy_last = 0;[/B]
case 'C':
[B]cpx_last = px2;
cpy_last = py2;[/B]
case 'c':
[B]cpx_last = px2;
cpy_last = py2;[/B]
case 'S':
var pos = dm[2].split(/[ \s,]+/);
//print( 'S4:' + pos.length + ':' + pos );
for (i = 0;i < pos.length;i=i+4) {
px[B]2[/B] = parseFloat( pos[i] );
py[B]2[/B] = parseFloat( pos[i+1] );
[B]px1 = px + (px - cpx_last);
py1 = py + (py - cpy_last);[/B]
px = parseFloat( pos[i+2] );
py = parseFloat( pos[i+3] );
[B]cpx_last = px2;
cpy_last = py2;[/B]
[B]splcore.curve(  ( new Vec3D( px1, 0, py1 ) ).multiply( scale ),
( new Vec3D( px2, 0, py2 ) ).multiply( scale ),
( new Vec3D( px , 0, py  ) ).multiply( scale ) );[/B]
case 's':
//print( 's4:' + pos.length + ':' + pos );
px[B]2[/B] = px + parseFloat( pos[i] );
py[B]2[/B] = py + parseFloat( pos[i+1] );
px += parseFloat( pos[i+2] );
py += parseFloat( pos[i+3] );
[B]cpx_last = px2;
cpy_last = py2;[/B]
you may see the difference in some control points.
Here the script.
Caution: before "Import" button clicking take the focus off from the scale parameter.
  • SVG Graph Loader.zip
