Move Mouth with Wave File
Here's 2 scripts to rotate a Jaw Joint according to a recorded wav file.
Most of the work was done by Hiroto. I just kept bugging him for tips.
"A Wave Loader.js" will read a wav file and create a *Rotation.txt file.
"A Rotater.js" will read the *Rotation.txt file and rotate a jaw joint and render to *.jpg.
There are some assumptions (15fps) and Jaw Joint must be the selected object when using "A Rotater.js".
Also, check the script to see if rotating the x or z coordinate.
You can use Blender or iMovie or both to create final output.
