Toggle Visibility.js
hello
this is a macro script to toggle 'visible in editor' of selected object at object browser.
[download] -> http://www.tres-graficos.jp/blog/files/article.php?id=61
place this script file into ~/Library/Application Support/Cheetah3D/scripts/Macro folder.
update 20101125: now it works recursively.
you can assign shortcut key for this script via 'System Preferences...' -> 'Keyboard' -> 'Keyboard Shortcut'.
Fantastic, is there anything you haven't written a script for?
I've got it installed and working via the scripts menu but how do I make an object visible/invisible via the object browser?
hi,
please check 'visible in 3d view' of 'mode' tag of an object.
hello
I'm new to OS X.
I wish to add a shortcut key to the script.
I go to keyboard shortcuts and then i click on '+' icon. select the C3D app from the list,then give a name for shortcut 'Transparency' and i enter the shortcut key.
For eg: 'Apple key+ T'.
But how is the script assigned to this shortcut?
This maybe simple, i could have missed something obvious?
Thanks for your time.
The name needs to be exactly the same as the .js file - do that then it will work. Hope that helps!
Hi friends,
i downloaded this script and added to the scripts folder.
Then re-started cheetah,reated a ball object, selected it and executed this script. the object visibility stays the same. :confused:
i'm on C3D 5.6.
I also tried the 'Toggle Shading' script and nothing happens.
(The expand selection tool works fine.)
how to solve this issue? any clues?
There are 5 folders at least to organize scripts when you open the main script folder:
•Tool
•Tag
•Polygonobj
•Macro
•Splineobj
You don´t have to restart Cheetah3d to use a new script: There´s a last menu item at the script list called "Update menu". This will do it.
