Tiles Object Chunker
I modifier the object chunker script a bit.
Normally the chucker takes an input object and creates new objects of a certain poly limit. For example, it could take a mesh of 1000 polys and it would create 5 meshes with 2000 polys each.
The problem I had with the original script was that the new objects could contain polys from anywhere on the original object. My modification takes a tile size instead of a poly limit. So for example, if you use the script on a terrain about of 1000 objects and give it a grid size of 2 (meaning 2 x 2 grid), you'll get 4 objects. Each object is a tile in the grid which contains the polys from the original object that were contained in that tile.
I hope my description wasn't too confusing and that someone finds this script helpful.
Ken
Ken
