Some hints on Blueprint Object Setup...
frank beckmann
Active member
18,162
...within Cheetah3d.
I highly recommend to do the preparation elsewhere and bring just square images into the blueprint object - as it will go stroke upon stroke.
As I find most blueprints were a stack of orthographic views on one sheet of "paper" it is essential to make the cropping absolut symmetrical (talking of symmetrical objects here);) .
When you just go for cropping from a larger image, you have to be aware the aspect ratios and have to adjust it in the Blueprint object properties.
Aunt Edith says: "If this all means too much work for´ya - nobody is holding you back from using one Blueprint-object per blueprint; you just need to know the size to enter into the x,y,z-properties to maintain proportions - scaling can be done right into the 3d-view accordingly!
And keep in mind your texture size don't exceeds the 2k (2048x2048px) OpenGl display limit. Otherwise interpolation will come into play."
Yeah - but what still confuses me is it exchanges images from front to back and vice versa resp left/right/top/bottom.
:sick: I recommend the comments by the late Chinese philosopher, 孔夫子, *551 - †479 BCE. He had much to say about confusion.
