OBJ Importer.js
OBJ Importer.js
hello,
this is importer for OBJ file with multi material assignments. for a file from Poser or Ivy generator.
http://www.tres-graficos.jp/blog/files/article.php?id=47
DEMO MOVIE (YouTube) : http://www.youtube.com/watch?v=Enbf2djoCpU
UPDATED 20090412: optimized speed, added progress info at Console view.
UPDATED 20090413: material import improved.
Thanks a bunch.
Wow - and another great addition from script-wizard Hiroto.:icon_thumbup:
(Uncle Bob will love this one especially.)
Regards
Aunt Edith says: "Cheetah3d v6 has a native OBJ importer implemented."
This is great, I was needing this exactly right now, Thanks Hiroto :icon_thumbup::icon_thumbup::icon_thumbup:
AaronC
I havent tried it just yet but I noticed the download arrived without the .zip extension? renaming it fixed it up , but I just thought Id mention it..
AaronC
Just used it!
Regards
It is a great script very nice. Just what I needed.Thanks Hiroto.:icon_thumbup:I have a question though. I don't see the progress report what window do you see them in? Thanks
Umm. now it works properly. if the file didn't work, please download it again.
> uncle808us
thank you for your comment. :D
the latest version is OBJ Importer.js_20090413.zip, the first version had a lot of bug. please use the latest one.
about Console view, please see attached pic. usually, I choose custom layout when I use scripts.
Thanks figured it out...
> uncle808us
:smile: Thanks This is so useful.
bug with 5.0?
Hi Hiroto,
with C3D 5.03 i got an error in Line 362 :)= couldn't find colorColor parameter). Geometry is imported fine, the problem is only about materials (as expected with the new MatSystem...). i'm tryin' an .obj file that worked fine with 4.7.
thanks in advice,
regards,
p.s.: great materials preview in your blog!
hi, thank you for reporting.
yes, some of scripts that I wrote doesn't work correctly with new material system of 5.0. To fix it, I have to wait that Martin will update script system. ;)
till that, you have to add material manually.
thanks. :)
regards
Hi Hiroto, I just noticed this was not working. I wonder if the new javascript engine makes it easy for you to fix?
Thanks again for your great help
AaronC
Hi, thanks for reporting.
due to script engine change, some code of this script didn't work properly.
I fixed that problem temporarily, so please update it.
still, material import function doesn't work, but geometry will be imported with polygon selection for multi material assignment. please next update.
Any chance of seeing an update to this great script? Or is it still out of your hands Hiroto?
To anyone following this one I've asked Hiroto about the possibility of updating this script but it's currently not possible
thank you for asking this. actually some japanese user wants too; good .mtl importer. so, I will update if script will get material accessing API. ;)
