Flatten Polygon
kraus
5
Flatten Polygon
I've created a small script that flattens a polygon. It will make sure that all the vertices are on the same plane. Put in into your macro folder and enjoy!
Flatten.js
Cheeers
marco
wow
what a great idea! i've thought about a script like this many times...well done and thank you
Hi, so nice!
so, multi-selection version by adding some codes might be better.;)
Thank you for the replies. tg_jb modified the script to support the selection of more than one poly. You can find it here:
Flatten.js
There's a caveat with this version, though: If the selected polygons share edges or points, updating one polygon might affect already flattened polys. One would need to isolate these points and constrain their movement. I'll have a look at this problem when I find the time. ATM, I'm learning for my exams, so there's not much time left for coding and other fun stuff :(
very nice script. It's great to see another scripter. The more script writers the better. :smile:
P.S. Good luck for your exams.:icon_thumbup:
I tried to get this to run again and finally it works:cool: :D
If you have a load of polygons and the feeling it´s not really plane call the script a second time.
Put it in the Macro Scripts folder.
Happy flat Easter Egg Holidays.
PS: Aunt Edith says you can scale a bunch of geometry now along it´s normals or any direction with the gadget mode: second image.
  • flattened4U.js.zip
Picking up an error here:
line: 63
error: Can't find variable: printVec3D
C3D Version 5.8
AaronC
So you haven´t try the modified script from my reply N°6 - which still works.
