here you can find the Cheetah3D 3.6 documentation as a PDF file: http://cheetah3d.com/download/Cheetah_Manual.pdf.zip Many thanks to Daniel Leavey who did the conversion. Bye, Martin |
This is really great
Thanks Martin & Daniel, Greg |
getting errors trying to open the pdf.
"some data in your zip file is damaged. the CRC is c42b2a61 but should be 83e6d536" |
I've just tried it again and it works fine for me. Which version of OS X do you use? Bye, Martin |
I didn't generate this PDF and I also can't modify or maintain it. The the help will stay HTML for the first. But it is good to have a PDF version around for those users who prefer a PDF. Bye, Martin |
It's Dan here. I created the PDF of the manual and sent it to Martin as a .zip file. Believe it or not, I'm also had problems with the .zip file download. I could unzip it, but Acrobat had trouble reading it.
I've made a fresh .zip file of the PDF and decompressed it and opened it in Acrobat on my hard drive with no problems. I can send the .zip file directly to anyone who wants it (7.2 Mbytes), or as an original PDF (10.2 Mbytes). I'll also send Martin a copy of the new .zip file for the manual. Dan |
Hi Dan,
thanks for the file. I've updated the link above. So everybody who had problems with the old file can try the new one. Bye, Martin P.S. I've downloaded the old file again and it worked perfectly in Preview.app on S X 10.4.8. |
pdf worked perfectly in preview, thank you much!
It would not open in Adobe Acrobat Reader, though I am using 7.0.6 and I haven't updated to 7.0.9 yet. Cheers, Chuck |
I just tried it with WIN and Acrobat and I couldn't open it after unzip. So I have to try it at home with MAC OSX. But I'm happy to see that there is a pdf! best regards Wolfgang |
The pdf file is corrupt.
A window quickly appears and disappears ... it has the word corrupt in it. Then an error window appears: 'There was an error opening this document. There was a problem reading this document. (14)' Adobe Acrobat 8.0.0 |
| Display Modes | |
