Grapher.js (function plotter)
the attached polygon object script can be use to plot some simple mathematical functions.
The script supports normal arithmetic operations like +-*/ and the following built in mathematical functions: abs(), ceil(), cos(), exp(), floor(), length(), log(), max(), min(), pow(), random(), sin(), sqrt(), tan().
You can use the script to generate objects like the one shown below. The sample file which was used to generate the screenshot comes with the script.
I hope you have some usage for it.:smile:
  • Grapher.zip
WoW - this is great Martin - thank you!!!!
I'm not much of a math wiz - I'm having to summon my highschool algrebra and PreCal lessons to begin playing. The built in functions look pretty diverse as well - I'm going to have to play with the "random()" function ;-) and see what comes about.
Looks like it could be good to create parts of a mesh that need some of the surface dynamics that math can provide.
The "t" can be keyframed - which means we can have a graph animate over time - awesome!!!
Also it works perfect with Particle Mesh - which means I can have Objects layout on top of the Graphic Mesh (with particle tags) and pretty much animate the whole thing (see images).
Lots of potential - will be interesting to see what I can apply this towards
Thanks again for a great script!!!!
if you could explain how using it, i'll be glad,
thank you
to install the script you just have to download it and copy it into the following folder:
~/Library/Application Support/Cheetah3D/Scripts/Polygonobj/
Restart Cheetah3D. Now you can access the script via the "Tools->Scripts->Polygon script->Grapher.js"menu command.
Please see also the "Executing a Script" chapter in the Cheetah3D Help files.
Hi Martin,
Thank you for answering.
ok! i suppose that my English , now,became really bad...
cause i do not ask how to install a script, or how execute a script,
but just how obtain the different results which appear on page "Grapher.js (function plotter)" cause when i load it, and put random numbers, nothing happen...
I should have writing:" if you could explain how using it, to obtain same results as yours ..."
My fault, i do not ask well my question.
Regards
Hervé
PS: Martin, with Cheetah 3D, you have creating a wonderful software which is able to "almost" take the place of C4D for a tiny little part of C4D price...
Congrats
Hi Hervé,
the script comes with a sample file called "sample.jas". Once you've installed the script you can open the sample file properly. The sample file contains the 4 examples shown above.
Congrats
Thanks.:redface:
Hello Martin, everybody,
would the formula's from this web site work in your Grapher script?
Some of the parameters might require adjusting - renaming, or other changes.
http://www.atlantis23.com/ei_parmsurf/parametricsurfaces_catalog.html
That's not possible yet. But only some small modifications are necessary to create such shapes. I will soon release a updated version of that script which will allow more complex shapes.
Here is a screenshot of the upcoming script.
