Recreational Vehicle Build
It was I finally understand how to cover and rotate. Nice also the tip about using subdivide [setting linear 1] for quads is handy.( I knew this but never used the knowledge.)
How did you figure out the rotate and cover action? It would and never did occur to me.
Again thank you for taking the time to make the pdf.
Cool, you made my day.
Try using the Subdiv Modifier the same way for smoother results.
It smooths and subdivides, while Linear Subdiv will leave the wheel
wells with flat spots. Catmull-Clark or Stam-Loop should work.
Sounds like a shampoo commercial.
I swear I posted GIF 4, 5 and 6, but there's no sign of them so here are 4 through 8.
The next PDF is nearing completion, but I've been dealing with
other things like dental appointments, and some spring cleaning.
Oh yes, and I got my new Mac Hex "Trashcan"!!!
Not hooked up quite yet, a new monitor was on order and I just got it.
The best monitor my research could find was not the Apple but a
Dell UltraSharp 27"- 1.07 billion colors, DeltaE less than 2,
GB-LEDs and DisplayPort 1.2 High Bit-rate 2.
