Well, from when I was using the software I don't recall seeing any small icons above the 3D view that could be used for manipulation other than the apparently "all in one" transform tool... somebody posted a screenshot which showed separate "move" "scale" and "rotate" icons which I have as of yet to locate anywhere in the interface... maybe it was from an older version?
The camera navigation icons are always there. See first screenshot.
To get the other transform tool icons you have to customized your toolbar. Right mouse click into the toolbar. See second screenshot.
I have found that at all times I CAN move and rotate objects using the increments off to the right side of the 3D view, but that's kind of inconvenient as opposed to being able to just "free-hand" move and rotate the camera or objects at will.
For object transformations use the transform tool.
For camera transforms use either the camera controll icons or the ALT+ dragg. Moving the camera is needed way to often that it would be effective to select the camera object and use the transform tool. Therefore there are these to dedicated camera navigation options which always work. Even when the camera is not selected.
The oddest part about this is that after option+leftclick+dragging to "rotate" the view around a few times, not only do I suddenly lose the ability to freely "move" the camera around (by regular leftclick+dragging anywhere in the 3D view) but I ALSO lose the ability to freely move ANY objects around the same way; it suddenly makes it so that if I do have an object (let's just say a single cube) and I select it, then click any empty space in the 3D view and drag the mouse, with NO modifier held down, it ROTATES the object around INSTEAD of changing its coordinates at all, and once this happens there seems to be no way to get the "transform" tool to go back to "moving" the object around other than by relaunching the software =(
If you want to rotate a object rings of the transform tool highlight. If you want to move a object click on one of the arrows to enable the move mode. The arrows will then highlight and you can move the object.
Please see also the documentation of the Transform tool.
I'm quite sure there is no bug there. Otherwise I would have been flodded with bug reports already.:wink:
Bye,
