ZooHead
0
When that´s the case it´s a bug.
(I never use the camera view when in modeling-mode BTW )
But it happens with either preview or the camera, but we
can't see or screen capture the position of the preview view.
Strangely enough it don´t happen to me usually - but I´m sure it´s not intentional so please write a bug report.
You can check it in 4-window mode BTW.
Via email to Martin, because it´s quite an old issue and not only related to the v7beta version. Thanks.
Where should I report the bug now?
Hi Unc, a word of caution, when working inside a model don't use area select.
Area select will select what's behind the camera as well!
I don't know if this is intentional or a bug.
Are you working in v7? You can put the different meshes on a different layer and then turn the outer one off.
How do you create a layer?
Click on the color circle in the Object Browser (you have to turn those icons on first if they aren't already).
I'm not sure I grasp the concept. How does this help? Arn't groups the same thing?
Yes and no. They could have similar functions. If you group something, everything in that group will be moved into the folder. If you want to keep everything visible and in the same stacking order in the object browser, then you could use layers. Layers probably are most useful if you want to render different parts of a scene separately and then composite afterwords.
Just another method to organize a scene. Somebody else may add to what I've said though.
It is GREAT!I realize there maybe other ways to model the tongue but I want to follow the tut.
This is the tut: https://www.youtube.com/watch?v=p2dSFQahVqo
:icon_thumbup: Thank you so much uncle808us for the link to modeling the inside of the mouth tutorial ! ! !
It is GREAT!
I struggled for literally months trying to model the inside of a mouth so it could be easily
and nicely animatable and just couldn't achieve it.
Now I think I can do it.
My Best Regards
Jeanny
