Orthographic camera renders being very weird
Hey all.
I've made a very simple scene in Cheetah where every object is at an integer position and have the same dimensions. This is basically in order to test a game that has an isometric view.
In order to rotate around, I want to take renders from 4 different angles. So, I created 4 different cameras, each at a standardized and equivalent position (15,15,15) (-15,15,15) (-15,15,-15) (15,15,-15). They have equal values otherwise, and are all in orthographic mode.
Now check out the absolutely wacky renders from the 4 different cameras. They appear as if they are from cameras with very different values, rather than what I put in. I can't think of any reason for this other than a software bug, or I just don't understand how they should be working.
View the renders here:
http://img507.imageshack.us/gal.php?g=cityd.tif
Or go directly to each:
Also you can get the .jas file here:
http://www.mediafire.com/?sharekey=cda1c74781a9bf7490a82c7bb0fad7ade04e75f6e8ebb871
[EDIT]
I just took the first camera and moved it to the correct positions, and that inexplicably works. Are there some camera properties that aren't in the properties menu?
[/EDIT]
Hey all.
[EDIT]
[/EDIT]
