Making holes in a wall (with exact measurement)
Hi...
I need to make a wall with holes.
Draw 1 segment with 6 holes, then use the Particle Array to multiply, I guess.
Measurement has to be exact with numbers on technical drawings I have on paper.
I've been playing around for quit a while now... but cannot get it right.
Although not in an easy way.
It's a pain to make ringcuts in the exact spot, I do understand the numbers in the statusbar are %, but that is not a real big help as I s*ck in Maths...
I made blocks in the size where the ringcut must appear, used the blocks as a guide. But that takes too much time and is not 100% reliable either.
Possibly I am overlooking a very easy way to do it.
Perhaps one of you Wizards have the Golden Tip?
BTW: sizes in real-life are:
rectangle = 280 cm x 208,5 cm
hole = 60 x 85 cm
Space between holes = 20 cm
Space left = 9,5 cm
Space richt = 9 cm
Thnks, Miguel
Hi...
hole = 60 x 85 cm
Space left = 9,5 cm
Space richt = 9 cm
Thnks, Miguel
