converting extruded spline to polygon
I'm trying to complete what should be a simple task - I have extruded text and I want to convert it to polygons. Can you tell me how do I do it?
Simple I hope, but when I try it doesn't work.
Thanks.;)
can do the following:
1. Select the "Extrude" object in the material browser.
2. Call the "Tools->Make Editable" menu command.
Alternatively you can just double click the icon of the "Extrude" object.
By,
I want to do the opposite thing convert a polygon into a spline. Is this possible?
Morten
I think there's a poly2spline script somewhere on the forum, check out the scripts download section.
Andrew
Wow, what happened there then I thought I was answering Mortens post and it suddenly disappeared, spooky.
