Tiny, Tiny feature request-ette...
Martin,
In the Properties pane, would it be possible to make the Name fields for objects and textures wider? I tend to use filenames that are longer than can be accommodated at present. It makes it difficult to see what's going on.
Ta,
that would be easy to implement but than the text field of the name property won't be aligned with the text fields of the float or vector properties.
And I can't widen these fields since they my collide with some long property names on the left.
So it is actually not that easy.
The path text field of the texture properties is two lines. So it should be normally enough.
Martin....Can't it just go like this?????
Also, Direct editing of names in the property browser would be really welcome...
OK, that's two requests now...
would it be possible to have a box that aligns as you want it to Martin but is deeper... such that the text in it wraps...
just an idea...
cheers
Trevor
