Group Select problem
Hello there
I have a little problem that blocks me.
Suppose you have a polygon object constituted by two surfaces.
Each surface has the same number of points "connectable" to the other.
When I use Group Select selection type, each surface is individually selectable.
But when I connect these surfaces with "Weld", or "Create Polygon", I obtain a single surface. That's fine for small surfaces.
But for sides containing hundreds of points, it's really long to "Weld" or Create polygon for each rectangle.
Is there a quicker method to achieve that?
Thank You for any help
Richard
Here is an example:
Hello there
Richard
Here is an example:
