Serious problems with polygon selection sets
I'm pulling my hair out right now due to bugs with the polygon selection sets. I have a polygon mesh with several sub parts to it.
I'm trying to go through the process of creating polygon sets (selection group, polygon selection: 0, 1, 2, etc.) and assigning appropriate materials to each set.
The problem is that there are bugs when changing the active selection set. For starters, it seems that if I create 5 selection sets (# 0-4), then select the 6th (# 5) which has yet to have anything selected, it has preselected the same polygons as the first (# 0). Select the 7th (# 6) and it has preselected the same polygons as the second set (# 1). You seem to be doing some sort of modulus operation here.
That would be fine if I could then change the selection without it affecting the original set. No such luck.
Also, it seems that every 3rd or 4th time I change selection sets, they seem to move to another slot/set number or disappear entirely.
BTW perhaps a thing to add to the wishlist would be to use some inverted color for polygon selections. It's next to impossible to determine what's selected if you have reddish textures assigned.
Please look into this. Thanks.
