This took forever to render, but I love the end result!
Great lighting set-up, novolume! I wish more of this kind of stuff was available in the forums. :smile:
-- GS.
Looks good GS, might just benefit from bringing the overhead softbox slightly forward to light up the front a little more.
Just out of interest, how long did the render take?
Roughly nine hours, (it says 32,952 secs, don't know if I calculated that correctly). My computer isn't the fastest, it's from 2007 or so.![]()
Thanks for the suggestion! I'll try that.
-- GS.
Wow, that's crazy! I haven't rendered anything that took more than 20 minutes in a long time.
(so any comments / suggestions are welcome) ...
the pencils look awesome, there's just one thing that I would change: the point
graphite is a lighter grey and has a subtle reflection: you could try to use the current black/dark area as alpha for the wooden part and create a semi-metallic shader for the underlying graphite end... what do you think?
Is this better (I probably overdid the shinyness) ...
Yeah I agree maybe a bit much. It can vary greatly depending on the type of graphite in pencil. There's a hardness scale and a darkness scale for graphite. http://www.pencils.com/hb-graphite-grading-scale I think those look like pencils that you would see for scoring (like golf or bowling). They'd be in the darker and harder scale. Typically because the pencils would last longer, keep a sharper edge and the marks wouldn't smudge as much. I definetely like the chipped paint! It adds to making the image look more realistic. Thanks!
