multi-rows QTVR Object movies
Messages
1,944
- Please see this thread also
- Here is the multi-rows script that I had forgotten to upload
// Purpose : This script can be used with Cheetah3D to generate a series of images around an object.
// These images can then be used, with another program like Object2VR
// to generate a QTVR object movie or a Flash object movie
// This script has been tested with Cheetah3D version 5.7 under Snow Leopard
// Installation : To use it, place it into your "scripts/Tag" folder.
// More instructions in the attached ReadMe file and the script itself
Feel free to correct it or modify it for your own use or the C3D community
  • Archive.zip
In item 5 of the ReadMe file :
" ... I recommend to create first a new folder and then provide a generic name for the images ( eg : Test as indicated below ). This name will be patched with a number, starting with the number given in the script tag. ... "
Here is the "Motif" format to use in Object2VR program to use the above images naming convention (providing you start with 1).
