Problems with Import of Silo2 sia-files
Dranix
0
Messages
271
I've found a bug in the sia-loader: When loading a sia produced bei Silo2 beta Cheetah3D does crash in the loadercode:
EXC_BAD_ACCESS (0x0001)
KERN_PROTECTION_FAILURE (0x0002) at 0x00000248
Thread 0 Crashed:
0 -[mwSIALoader load:] + 6420
1 -[mwLoaderCenter load:::] + 660
2 -[MyDocument readFromFile:eek:fType:] + 84
3 -[NSDocument readFromURL:eek:fType:error:] + 144
4 -[NSDocument _initWithContentsOfURL:eek:fType:error:] + 148
5 -[NSDocument initWithContentsOfURL:eek:fType:error:] + 264
6 -[NSDocumentController makeDocumentWithContentsOfURL:eek:fType:error:] + 332
7 -[NSDocumentController openDocumentWithContentsOfURL:display:error:] + 340
8 -[NSDocumentController openDocument:] + 432
9 -[NSApplication sendAction:to:from:] + 108
The sia (containing only a cube) opens fine in Silo.
  • test.sia.zip
A bug in the beta? Cheetah3d won´t load Silo2 beta files? That is true. So what? Are you expecting Martin rewrites a loader for a beta?:smile:
But why is it loadable without problems into Silo1.42? If there where a bug in the export shouldn't it hit Silo, too?
Edit: And yes, crashing shouldn't happen even when throwing trash at an app ;)
If you think so…
I may have been not clear: Cheetah3d is crashing, not Silo2... And that should never happen, even when feed a .doc :frown:
I know that, but you might know that the ".sia" file is a native Silo file extension like ".jas" is for Cheetah3d. And that one can use these sia-files along with Cheetah3d seems a deal so far. But again: Are you expecting Martin to rewrite a loader for a foreign beta?
BTW; you can try to ask Nevercenter, what changes they made.
since Silo2 is still beta so I can not guarantee that it really works. And there still might change things in the v2 file format. I just fixed the bug from the file squareitround.
But as Frank says. Since Silo 2 is Beta software things can change again with the next Silo beta.
Bye,
I've tested your attached files and Cheetah3D 4.3 already loads it fine.
Bye,
Bye,
That's nice but I could live with Cheetah not being able to load it - just the crash isn't nice.
No, I just expect that Cheetah doesn't crash on data it can't handle.
Frank has a tendency to get incredibly defensive about Cheetah bugs and/or feature requests. FWIW, I agree with you. While I wouldn't expect Cheetah to compensate for Silo's bugs, I WOULD expect it not to crash when loading a bad file.
Cheetah has a very loyal user base but that doesn't serve the community or the software development imo. People need to express honestly what they think could be improved or doesn't work in a tactful way and others need not be so defensive.
I'm going outside, it's 78 and sunny. :)
@ Willem: I personally agree with Frank, and as far as feature requests goes, if you are referring to the "Bevel/Chamfer tool" Post in the general section of the forum, I agree with him there too. the post was asking how to do something, and Frank offered a solution, then got in trouble because the solution was a workaround(Which the guy was asking for) instead of a "Martin, please add this to cheetah". I don't want to offend anyone, this is just my opinion. But I don't think Frank is being defensive. He is merely stating that Martin should not have to write extra code so cheetah can import files made in a beta application. No, I don't think cheetah should crash, but I don't think Martin should have to adapt cheetah to open files from a beta. Anyway, just my(Very lengthy) opinion.:redface: :wink: :smile: Go Martin!
@IDR: Same here!(Actually it's 79.8 and sunny):mrgreen:
