Edge N Splitter.js
Edge N Splitter.js
hello
It's a tool script to split edge with input number.
Place it into ~/Library/Application Support/Cheetah3D/scripts/Tool folder to install.
download -> http://www.tres-graficos.jp/blog/files/article.php?id=80
[CAUTION] Don't use 'undo' command after execution of this Tool!! It causes crash.
[UPDATE 20120413] undo/redo are available for only Cheetah3D 6.0+
This is an amazing script. I once asked Martin for an advanced ringcut Tool for multiple cuts. With your script and the scalpel tool I can adjust even&odd cuts through a mesh while keeping proportions - no other tool will do right now.
Thank you so much.
One thing though: Making an "undo" will crash Cheetah3d under SnowLeopard.
thank you for comment.
yes, It's not undoable, and causes crash. :(
but, I cannot fix it, I think it's limitation of script. please don't use undo. ;)
Very nice - thank you! Now if only I had this a few days ago when I was racking my brain on how to accomplish this.
--Shift Studio.
hello,
I updated this script for undo/redo function. please update it if you have upgraded Cheetah3D 6.0. :)
Hello Hiroto, I am trying to download this script but I get an empty document.
You have to go to Hiroto´s site first. And download from there:
Thanks Frank, but I've been there and done that.
I get a cpgz file that I've never seen before and that doesn't show on the download window,
but is showing on the disk and unpacks to the blank doc.
That looks crazy - maybe it´s a MountainLion/Gatekeeper thingy. Right-click/save linked file as.... isn´t working either?
I don´t upload the script here as I don´t want to override Hiroto´s donation-button.
Any other experiencing kind of crap download from Hiroto´s site?
Thanks for the "Right-click/save" suggestion, I was hopeful, but it is not working. Maybe a US problem?
Here's the solution Zoohead - I'm in California and did it this way:
Went to Hiroto's link:
http://www.tres-graficos.jp/blog/fil...icle.php?id=80
Clicked on download link & I got a file just as you described, named "Edge"
With the "Edge" file highlited, I hit "Return" once so I can rename it.
I add ".zip" to the end of the file and hit Return.
You will be prompted - select "Add"
Now double-click on file to unzip.
TaDa :)
R.
R.
Thank you so much Rene, that worked, now I just have to figure out how to use it.
It's not doing anything yet.
Thank you as well Frank. I thought, if he doesn't know what's wrong, I'm sunk.
Edit: OK I see, it doesn't connect the dots. To bad but still somewhat useful.
I still have no clue why the download is not working for you as expected. Maybe it´s the naming containing two dots confusing MacOS with the file-type.
Just for a test-run I uploaded it here for a few hours to see if you can download it easier from the forum:
@ Hiroto: I will take the script down later in the day.
That worked properly.
