SVG in Cheetah 2.6.1.
Being just a rookie in Cheetah i found myself in total dispair when i couldn't figure out how to give an imported SVG-file (Illustrator CS) a simple color. The only things i've seen so far are the outlines. No fill. I'am in desperate need of help.... someone? :-(
There's a tutorial about that somewhere, check the help section of Cheetah and do a search on the forum. I think you want to use the Extrude object. Once inserted in your scene drag&drop the SVG spline on the extrude object and change the settings of the extrude object to your likings.
Help with Cheetah
Take a look at the help file that comes with Cheetah it has a whole tutorial explaining what you want. :)
Andrew
