ripple+ script
I need some help with the ripple+ script. right now heres what Im doing and my problem, I select the script make the size I want then add one or two balls under it I check on use ball set the time to zero click record then i go a few frames forward and add time and click on drop ball click record, so the first time it runs through looks good but when it repeats the water doesnt start calm even if on the first key if i click calm and record no effect. and also how would u go about using more balls but timing them so after one drops another follows?
